alexandresynth
en respuesta a: alexandresynth
Here comes the bugs related to LayerState:
1 - The checkbox "Turn  off layers not found in layer state" works parcially, it really shows a result in viewport (that is why was approved by the tester before being released, a bad tester didnt tested 100%) but is ignored when you print.
2 - The cronic problem of the "unsaved layer state" that many ppl already reported in different foruns in different countries was probably developed originally to make the viewport a "slave" from that layerstate and not suffer changes when you change the layer state in model, during the development of the project, but some code mistake makes autocad forget the layer state saved in the minimum touch you do in any other command and it returns to "unsaved layer state" it causes every time you will print, you need go to each layout, click twice in each viewport and choose the right layer state before you print.
3 - When you change color, tickness, linetype, etc...except name, the name always change correctly if you change in model, from a layer, it is completelly ignored in layout when you choose the layer state (PS: I am talking about change in model, not the VP color!), when you choose a layer state for the viewport it will bring the color, tickness, linetype, transparency, probalbably the description too, i never tried, that was set when the layerstate was created and ignore any change from that point. Except the name, the name always change properly and correctly following what was made in model. The only solution for you to be free completelly of autocad restore the old layer status (color, linetype, etc...) is if you delete all layer states, save, close autocad, open again, performance all changes in all layers in model and after it create again each layer state.
This bug of layerstate forget the changes made in model and saved in layer state also occours in model, not only inside viewport.
I never performanced changes in VPCOlor or VPLinetype
I also never performance changes inside the edit layer state
Every change is performed directly in model
I use the newest version of AutoCAD 2025 and it is original i can even give the information of my account if someone from technical support contact me.
These bugs are very old, i spot them in 2018, i dont know if is older than that, and i was hoping that in 2019 or newer would be solve, which never been so far.
