cadffm
en respuesta a: alexandresynth
Hi alexandresynth,
oh darn, I only saw your second post (7#7) and wrote my detailed answer to it. Now I see 6#7 and will initially only refer to post #6
If you like to get the whole reply, tell me - it's ready. Just short for now.
Regardless of what you call the problems or not, your answers show so many problems with understanding layers, layer status and viewports that you really should look into them.
This will not change the AutoCAD program and the desire for more functionality will remain,
but you will have so many fewer problems with the program if you understand how it works.
You write about things that don't work, but which have always worked for me (100%) for 15-20 years and I am sure it is not my fault, but the program's.
You report mysterious things that are very easy to explain, at least as long as no further explanation is given.
I keep coming back to the same point in your explanations:
1. I miss what you miss too.
2. You waste a lot of time unnecessarily because you don't have a proper overview of the connections (viewport overrides).
The question remains whether you are open to dealing with it.
Real user,
Sebastian
Sebastian
