- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
The situation is the following: You think that autocad does not have a bug in layer state, but its a resource that autocad dont have.
But IS NOT THIS that i am talking about!
I am talking about the resource that we have now, the layer state behavior is erradic from the beggining to end, you click in ok it does not save, it shows it right you blink your eyes and it return to previous state, you change the color of something in xref it does not apply to your main drawning, you delete the xref and upload again you print one time but if you close and open autocad and open again autocad will fool you and it will magically return to previous state, then u need to unload both files from each other, close autocad then open again and load again then it works, the "dont show layers not listed in layer state" does not work, the layers property manager from: Model, viewport and Layer state act like 3 different layer states who dont talk to each other so many conclicts happen among them.
The list goes on and on: The whole layer state/ viewport situation should be reviewed, fixed, re-programmed, re-designed.
The system analitic who tested the program after the programmer finished the code didnt tested it right and didnt tested it full, and a version full of conflicts and bug was released and they nevermore touched that because guys like u defend that is not a bug even when it clearly is.
I am not asking for a new resource, i am asking for them to do the existent resource works.
Another victim of layerstates below:
Re: Layer states not staying applied - Autodesk Community - Civil 3D
