- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
"- You have to set all layers to ON and THAW if you want to see there objects anywhere in the file."
This is also not the solution, because i will have organized and visible viewport but i will see every layer turned on in model, and i will need manually turn on/ off a huge amount of layers we work in model without forget anything.
i need to have each one of the combinaitons of layers available in model AND in layout.
That is why layer state works in first plan! to filter the project! to allow us to see each subject of the project separated from each other, but it does not work properly, it happens a dozen of conflicts. PLEASE AUTODESK FIX THE LAYER STATESSSSSSSSSS
When you will stop defend autocad and realize that there is a bug and need to be fixed? It will be benefict for both of us!
I also can find a way to work using dirty strategies like you do, update here, save there, stand up from my chair turn around and give 3 jumps, do the rain dance, sing some voodoo songs... i use some black magic strategies and in the end it works too, otherwise it would be impossible to do the project, but it consumes a huge time! I am working to dodge the bugs of autocad in Layer states.
As you said, Layout cannot be liked in definitive to a layer state, yea, i know that, so lets ask them to change! its a mistake, an error! every single time i need to switch each layout, enter each viewport and choose right layer state again and again each time i will print. And its so bizarre that some viewports dont need to be update, and others need, maybe the viewport never forget the layer state that was choosen in the moment when it was originally created, to be true i am not even interesting in do some tests to comprove it, but is probably...possibly it.
And the lists of errors that you will not be interested in accept are bugs goes on and on.
I added a xref that i want to displayers their layers only in 1 sheet (only in 7-7 СПИС) the others layers states didnt carried the layers of the xref, as you can see below.
I didnt click to add, so the layer state didnt know about the existence of those layers, and i kept checked the box "turn off layers not found in layer state", and autocad even did it, indeeed i went to first viewport, choose the layer state 1-7 Схема УЗ, autocad shows the right layers, i went to the next layout, choosed the right layers state, until the seventh, when i print, the layers of the xref were displayed in ALL SHEETS!!!!!!!!
And then will come an specialist here and tell me it is not a bug. how much u bet? Man, how much AutoCAD is paying for you do this to me?
@alexandresynth - this post has been edited due to Community Rules & Etiquette violation.
