en respuesta a: Alfred.NESWADBA
  Hi Alfred,
My problems seem to have started after I downloaded 2015 without uninstalling 2016 first, so I had both of the versions running on my system. (I had way too many problems with 2016 so I gave up on it) I tried several times to re-install/repair both versions but could never get the programs back to their  original default state. Over the last month things just got worse and worse. For instance I lost all my snap points in Conceptual mode so I would have to do all my snaps in 2D wireframe. (can you imagine!) ha! Objects would suddenly disappear or move. My material browser would crash the program when I tried to edit a material from the material library, all of my x-refs would turn into text and wouldn't reload because it couldn't find the path, and then finally I couldn't close either the window or the program without getting a Fatal Error message before crashing. What I ended up doing last night was to uninstall both 2015 and 2016 and then I uninstalled Microsoft.net Framework and a whole crap load of Microsoft Visual C+ files, and various other files that the uninstaller didn't get. I then re-installed 2015 and now everything works great.  I finally got the program back to it's default state!
I'm taking an online course in AutoCAD right now so I'm fairly new to this stuff but if I had to do everything all over again I would of downloaded 2015 and just skipped over 2016. Nothing ever worked right for me with it. Good Luck  everyone.
