- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
it IS a mistake, stop fool yourself and the others. Also remove the title of expert in autocad from your signature.
Are you an real user of AutoCAD? Really? Or u are just a teacher? Send me your project i want to see it, because is just IMPOSSIBLE u do a real full architecture project without use the layer states, is just impossible! How will u deal with a million of layers in your face turned on at same time??
Without layer state
With Layer state
I NEVER changed the overwrite configurations of layer inside the late state, i even think an interesting idea for some occasions but i NEVER used. All the changed i do are in MODEL but the problem is that when i go to layout i never over and over again choose the layer state for each viewport in each layout and any change of layer (color, tickness, printable or not, transparency, etc...) when i change the layer state all them are LOST FOREVER!!!!!!!!!!!
The only way to keep them are 2:
1 - Or i delete all layer states, do the changes i want in layers and then create one by one again.
2 - If i choose each layerstate, perfomance all changes in each layer (in model, not editing anything inside the LAS layer overwrite) and then i open the LAS and click in update. After that i need to choose the next layer state, performance the same changes in each layer and update again, is not "only 1 click" as u said.
What happened was the following: the programmers programmed this resource, the system analyst did a very poor test because he wanted to go home fast to play Age of Empires, so hr gave his OK and it was published without further investigations and tests and we real users (not you) are paying the price of that tester 10 years ago until today. And it is still alive despite many ppl complain about the same problems in many foruns in many countries because ppl keep defending that is not a bug and we just dont know how to use.
It carries a BUG inside, everyone who read this in the future keep it in main!
You click in ok but it will not be saved, you change something and this change does not stay.
