- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@cadffm schrieb:
>>"but the fact is that this is an error in AutoCAD."
Nope. You are expecting an different result, but this tool is not what you are after.
What you like to have ist not possible (until today).
..because1
Layerproperties (layer on/off freeze/thaw) in .DWG/DXF are global settings (global means everywhere inside each file),
You have to set Layer ON and THAWED if you want to see layer objects wherever in your file, it isn't independent of layout viewports, so it is not possible in .dxf / .dwg format
So it is not possible to by simple 3rd party tools to have all your wishes,
but it is possible to associate layerstates to viewports by tools.
But that doesn't completely solve your problem in dealing with the layer properties ON/OFF FREEZE/THAW.
Everything else is possible.
Sebastian
