leticia.campanelli
441 Vistas, 5 Respuestas
automatically setup not printable layers to not be shown in viewports.
Hi there,
I am wondering if there is an automatic way to setup the non printable layers to not be shown in the viewports.
I usually simply freeze them in the viewport, but for this specific project it is boing time consuming.
thanks
cadffm
en respuesta a: leticia.campanelli
not ootb, but with few lines code and the native command VPLAYER, no problem:
(defun c:AllNoPlotLayers2VPFRZ (/ a b)
  (setq b "")
  (while (setq a (tblnext "LAYER" (not a)))
    (if (zerop(cdr(assoc 290 (entget (tblobjname "LAYER" (cdr(assoc 2 a)))))))
        (setq b (strcat (cdr(assoc 2 (entget (tblobjname "LAYER" (cdr(assoc 2 a))))))"," b))
  (command "_.VPLAYER" "_fr" b "_all" "")
  (princ)
Sebastian
leticia.campanelli
en respuesta a: cadffm
feeling stupid. :cara_con_lágrimas_de_alegría:
Thank you so much, but I have no idea how to use this code.
is it easy enough to explain it here?
cadffm
no problem.
For usual you have a .lsp (or /.fas./vlx) file with code inside, so you can drag&droop the file into your drawing or
load it by command APPLOAD (often you will see informations about loaded function names in commandline/Textscreen [F2]).
In the case here, you have the (Lisp)sourcecode only, so you have to create a .lsp file yourself:
Open EDITOR, copy&paste the code into, save as <Name of your choice, but often the part after "defun c:" is senseful :cara_guiñando_un_ojo: > incl. the file extension .LSP
In this case here:
Save it to your new AutoCAD Custom Tools folder wherever\Tools\AllNoPlotLayers2VPFRZ.lsp
Now, you can load this file by drag&drop into your drawing or by APPLOAD command.
Note: In APPLOAD dialog, you can set up Acad to load this file into every file by open that file.
Sebastian
cadffm
thank you!!!!
