You can insert blocks in dwg, export their attributes to csv/txt with the ATTOUT command from Express, define the numbers in Excel or the like, and import in the attributes in dwg with the ATTIN command.
For attribute numbering when block inserting, there is a Lee Mac program that is about 20 years old. Search gives many others - you should try them.
-- Alexander, private person, pacifist, english only with translator :cara_con_una_leve_sonrisa: --
Object-modeling _ odclass-odedit.com _ Help
