cadffm
en respuesta a: peter.roman
there is no native function in plain AutoCAD to do what you want, but manually it is a simple 'move'
Open the block by BEDIT
MOVE ALL objects from <coordinate near to the objects, f.e. 1000000000,70000000,0>*
to <0,0,0>
and save your edit.
MOVE your blockreference from 0,0,0 to <1000000000,70000000,0>
Or before you insert the dwg as block:
OPEN this file
make sure UCS WCS is current
check out your INSBASE setting,
is it 0,0,0? ->
move all objects from <1000000000,70000000,0> to 0,0,0
or is it not 0,0,0?
Sebastian
