cadffm
en respuesta a: MaccyDee
This obscures or repairs the still existing problem (the unwanted dimscale change).
>>"... ineeded to add a line "
This isn't a solution, you've just created another problem for yourself.
Use a dimension style in which dimscale is set to 2, your script will now create an override again!
You should investigate the problem, I would be happy to help
Sebastian
