Tallans422
364 Vistas, 1 Respuesta
Drag and Drop Detail .dwg files into CAD
Back in release '23 I reached out to support because I could not drag .dwg files of details from file explorer into my active drawing (I would get the no ghost logo).  Autodesk recreated the issue on their end and said it would be escalated so I waited to upgrade.  I see there was a fix issued, they stated it was due to a Microsoft LUA policy and if you turn it off in the registry it would be fixed.  I made the change and still have issues consistently dragging and dropping dwg files into releases '23-'25.  Has anyone else experienced this?  Again, it's intermittent so for my example it works for a few, then stops.  Then later on it might work for one more, then give me the symbol again.  Windows 10 PC and been using/continue to use drag and drop in releases up to 2022 with no issues.
pendean
en respuesta a: Tallans422
No issues here in Win10Pro with fully updated AutoCAD 2023-24-25: acts like CLASSICINSERT command.
