Kent1Cooper
en respuesta a: trEQ4GG
Try it without the pen-down/pen-up numbers at the end of the first line.  I think I've seen the same problem before -- that it doesn't like a zero-length pen-up, which in any case should be negative.  Those lines are continuous anyway -- no need for pen-down/pen-up.
*LVT 6.25x42 33% Offset, LVT Pattern
0, 0,0, 14,6.25
90, 0,0, 6.25,14, 6.25,-12.5
You might be interested in RunningBondHPG.lsp, >here<, which can construct the pattern definition of something like that for you.  You just give it the element size and the amount of stagger you want.
Kent Cooper, AIA
