Kent1Cooper
en respuesta a: aj499V6MX
You don't say whether you've tried all the suggestions in that error message.  What have you tried for connecting at the gaps?  If that is made up of only Lines, Arcs and Polylines, try PEDIT, the Multiple option, select everything, the Join option with a fuzz factor [which the JOIN command doesn't have] large enough to find ends close enough to connect.
Another possibility:  Are you doing the HATCH by picking inside areas, or by selection bounding objects?  Try the other approach.
Kent Cooper, AIA
