aj499V6MX
541 Vistas, 5 Respuestas
How to fix disjoints to fill a drawing to be used for lithography
The attached picture is my microfluidic device and I have to develop this pattern on a silicon wafer using a maskless aligner. But for doing that I need to fill the channels inside it, and when I am doing it with hatch command there are lots of gaps being found in the drawing. I tried correcting it with AutoConstrain but it still does not work. I have attached the errors I am receiving while using hatch and the other image depicts the places where it finds gap. I have tried to manually also correct the disjoints but then when I run hatch command it shows disjoints somewhere else and it becomes a never ending process. Does someone has any suggestions for this?
Design
Error:
