paullimapa
en respuesta a: sam_schmitt
Well since you still have to determine which of the blocks you want that circle, what I would do is select only those and then wblock or cut & paste with base point those out. Then open the wblock or in a new dwg paste with same base point and then do a block edit to include the addition circle. Rename that block and now insert explode that dwg into your original drawing
Paul Li
IT Specialist
@The Office
