TasnimTarannum
189 Vistas, 1 Respuesta
Autocad Don't remember polysolid setting
I've noticed that when I use the "polysolid" command in AutoCAD, the height always defaults back to 1 inch after I exit the command. I usually set it to 11 feet, but it doesn't remember my preference.
Is there a way to make the height setting stick or save my customized settings so that I don't have to reset it every time?
Valentin-WSP
en respuesta a: TasnimTarannum
@TasnimTarannum ,
The POLYSOLID command should remember the input after exiting the command.
Consider the following:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
