IanMcClain
258 Vistas, 2 Respuestas
Snap grips are including coincident objects
I have some lines / poly lines with common vertices: when I select one object's snap grip to move it, all other coincident lines are moved with it, as if I had selected all the objects.
I have not seen this behavior before today. I assume it is some system variable, but I have no idea what is causing this.
How does one stop/turn off this behavior?
Ian McClain
