05-02-2024
11:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-02-2024
11:15 AM
I have some lines / poly lines with common vertices: when I select one object's snap grip to move it, all other coincident lines are moved with it, as if I had selected all the objects.
I have not seen this behavior before today. I assume it is some system variable, but I have no idea what is causing this.
How does one stop/turn off this behavior?
Ian McClain
¡Resuelto! Ir a solución.
05-02-2024
11:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-02-2024
11:34 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
05-02-2024
11:34 AM
That was is. Thank you!
DELCON allowed me to remove the constraints from objects that I had inadvertently created.
Setting the system variable in my SYSVARMONITOR to CONSTRAINTINFER=0 should prevent it in the future.
Ian McClain
