- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
tool palletes blocks rescaling and associating with lines
when i drag a block from the tool palletes it just looks to "want" to associate to a line, i just want it to stay on the intersection point of the lines
and if i put it anywhere else it is on 0.007 scale, very annoying, can someone help me please?
here for any questions.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Are you aware Dynamic blocks can be set to do things like that? it seems to be what you are using, someone at your end designed it that way, any idea whom?
You also don't appear to be manually and deliberately running the INT osnap either, so I can't tell from your picture why AutoCAD would just click on that intersection by itself either.
You can always include your DWG an that block in it right here for others to look at if you want, may not change the reality of what I typed though.
