BillAllenSE
639 Vistas, 4 Respuestas
AutoCAD 2025 - Purge All Button Doesn't Gray Out
Is it just me or is this a problem? When I click on "purge all", the button doesn't gray out. Yes, I've checked every check box. Yes, I know there are some non-purgeable entities. It's just that, when I've done this in ACAD 2024, it would gray out when I perform a similar operation.
TIA
pendean
en respuesta a: BillAllenSE
You'll need to report that to Autodesk yourself: nothing for end users to fix as far as I can tell.
Here is how to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
BillAllenSE
en respuesta a: pendean
Thank you, pendean.
I've submitted a support case and I will report back when I get a response.
BillAllenSE
Autodesk says the developers are working on this issue. The current workaround is to leave the Orphaned Data box unchecked.
pendean
Thanks for the workaround
