- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
"Or explain why that won't work"
i am making strata plans with polylines that calculates area using "fields". basically I have a table of area all pointing at each specific polyline already setted up and each polyline will be assigned a unit number (so its not as easy as to just rerun data extraction) .
problem is if a floor plan gets changed and all the changes need to propagate to all the floors. So what I hope to achieve is to create point on what has changed on floor 1 and copy those points to other floors to apply the changes. Alternative as you suggested is to create polyline for floor 1 and copy and deleting to replace the poly line on other floors. That would mean I need to re set up the area table to point at the right polyline.
I've attached a drawing on what I mean. Basically make the exact same change to all 4 polyline while maintaining the area table
