04-18-2024
01:18 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-18-2024
01:18 PM
@paullimapa wrote:
... you can try opening those xrefs clean them up, freeze layers you know you don't need to see and then do a save.....
Alternatively, depending on what Layer are involved in the excessive level of detail, you might be able to simply Freeze some of the Xref Layers in drawings in which they are Xref'd. That way, with an appropriate VISRETAIN setting, you don't need to do anything more when you get an update of those drawings. If you Freeze or delete Layers in those drawings themselves, you'll need to do it again when you get an update that contains stuff on all those Layers again.
Kent Cooper, AIA
