- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When I open a particular drawing, only half of the screen is used.
Other drawings use the entire screen.
Restarting the software and laptop didn't help.. any sugestions?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You also want to ensure your AutoCAD is fully updated, your ABOUT command in the program should show 2023.1.5
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Since it only happens with this one dwg and not others try running the Audit command. Or open this dwg using the Recover command to see if that makes a difference
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Maybe you need to set it to one viewport:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for all the help! I switched to 2 Viewports and then back to 1 and it's OK now.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for posting this. I ran into this problem on a new DWG file recently. How the problem occurred was, I used the WBLOCK command to extract linework from a drawing with modelspace split into 2 viewports. When I opened the new block, the linework was on the left half of the view area, and the right half was just "dead" - no viewcube, and no way to interact with that side of the screen. So it was like having 2 viewports, but not quite.
Using the +VPORTS command and selecting "Single" did not fix the problem. But selecting 2 or more viewports, and then setting it back to single, did fix it. This worked from both the +VPORTS command, and the View menu.
