04-12-2024
05:10 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-12-2024
05:10 AM
It is probably your DIMLAYER System Variable setting. That is for a Layer to put all Dimensions on, and it can be set to a Layer name that is not in the drawing, in which case when you draw any Dimension it will create the Layer. Type in DIMLAYER and follow the instruction to use . to have it put Dimensions on the current Layer. The setting is saved in the drawing, so if it is happening in multiple drawings, you will need to set it in each one, and check in all your drawing template files.
Kent Cooper, AIA
