02-17-2016
05:36 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-17-2016
05:36 AM
The behaviour that you are seeing occurs if the circle being dimensioned intersects the gap between the mark and the line. It can be reproduced with any circle and isn't actually related the the viewbase command:
If you need the full lined center mark than you can override size of specific dimension via the properties palette.
Hope this helps.
Dan
Dan Scales
