we are writing in "AutoCAD" board, in AutoCAD isn't a feature to override dimension settings automatically,
so you have to search the source of it first.
Or if you are using Architectural Toolset, make sure the create-overrides option is off, as still mentioned above.
_ _ _
AutoCAD&LT
Q1: What product you are using?
Please share a screenshot of the dialog, command: ABOUT
Q2: Please share a sample: Start a new file, based on acad.dwt (or acadiso.dwt)
       2.1 Check your dimstyle about overrides now, are there overrides?
       Save this file and share
       otherwise save this file and
       2.2 Check your dimstyle about overrides now, are there overrides?
       please share this last saved version, otherwise
       close and reopen this file
       2.3 Check your dimstyle about overrides now, are there overrides?
       Use command: _.DIMLINEAR
       2.4 Check your dimstyle about overrides now, are there overrides?
       otherwise I have q question: When&where are the overrides you are talking about?
Sebastian
