pendean
en respuesta a: tonytwok
@tonytwok wrote:
You are right, but in this job I need to maintain the spacing I selected to fill the text inside a square.
Still doesn't explain why we can't see what you see in AutoCAD.
Also:
1) why is COLUMNS>DYNAMIC in use in your one-word MTEXT?
2) Why a set width?
3) what is your custom CTB file adding to the plotting?
4) If you are plotting from modelspace (that's what your PDF says), why is there no saved printer? No scale? wrong page size (portrait is saved, you created landscape PDF)
5) what is this setting for if I may ask? It does not seem to do much
if I adjust your TEXT to fix the rectangle
Then PLOT with these choices
I seem to get a PDF that completely matches the DWG
HTH
