04-04-2024
01:48 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
04-04-2024
01:48 AM
Of course, to work in a CAD program you need a solid model. SketchUp is a program for pictures, but not for engineers, and the imported models will be polygon meshes. To create ModelDoc drawings (using the ViewBase command), you need solids. You can convert polygons to solids using the ConvToSolid command. But this must be a single mesh enclosing the space and there must be very few polygons in it (otherwise it is simply impossible to work in AutoCAD). Imported meshes do not meet these requirements. You can try the AVС MeshToSolid plugin, which can combine multiple meshes before converting to solid. But in most cases, to get a quality CAD model, you need to remodel it in a CAD program.
