- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Exporting to WMF Format Without Displaying Clipped Block Boundary
I've encountered an issue while exporting the drawing to WMF format.
When exporting blocks that have been xclipped, the clipping boundary always appears in the WMF. Is there any way to hide these boundaries or perhaps make them transparent during the export process?
Any insights or suggestions would be greatly appreciated!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@ragemama
Welcome to the forum! Can you share what version of AutoCAD you are currently using?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Why not just use PNGOUT which displays lineweight and text correctly with whatever background you want? You can even convert the background to transparent with free online tools to include with customizing the ribbon and toolbars.
Both https://www.online-image-editor.com/ and https://www.online-image-editor.com/ will make the background transparent for you if you don't have any software installed for it.
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@TomBeauford Thank you for your response. I export to WMF primarily because I intend to paste it into Microsoft Word for creating text documents later. The graphic will include multiple buildings covering the entire base area. Png format arent clear enough, and I thought WMF format can maintain higher resolution. If there are alternative methods or output formats,please kindly advise.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I don't use 2020, but in 2024 with the frame hidden WMFOUT and EXPORT (to WMF) commands do not show the clip boundary here when exported.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
thanks for the DWG file: see attached created with WMFOUT command in AutoCAD 2023.1.5 in Windows10Pro, I see no clip boundary, do you?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Until recent versions I'd always had issues with the FRAME system variables like IMAGEFRAME.
Even when they were set to 0 or 2 they would still plot so I toggled from 0 to 2 or 2 to 0 to get them to stop plotting, until I opened the drawing the next time at least.
Worth trying at least.
2023
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The issue persists when exporting certain hatch areas; the block frames are displayed as white lines within those hatch patterns after updating to the 2024 version. But the 2024 version is an improvement over the previous ones. Thank you very much for your advice.
