03-31-2024
03:41 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
03-31-2024
03:41 PM
It appears you already have the top view and the side view from B which leaves the section view A-A.
The section view can be thought of as cutting the object at the plane A-A and keeping everything in from the plane and beyond (direction of the arrow). The cut surfaces are then hatched to show them as cut. The larger three holes are no longer shown dashed as the hole edges are now visible.
Note that the picture does not correctly indicate the connection of gussets to the lower rounds - are they tangent to the 38 diameter or do they terminate above the centerline as shown?
