- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Help!! I am struggling to draw sectional front view, top view and side view of bevel gear support on AutoCAD. I need it as 2d and not 3d. anyone can help
I am struggling to draw sectional front view, top view and side view of bevel gear support on AutoCAD. I need it as 2d and not 3d. anyone can help please.
Maybe you have done It or you can show me or even a tutorial can do please.
Thank you!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
sorry my bad! I have attached the correct picture. I basically need to produce different views on autocad as a drawing with the dimensions.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It appears you already have the top view and the side view from B which leaves the section view A-A.
The section view can be thought of as cutting the object at the plane A-A and keeping everything in from the plane and beyond (direction of the arrow). The cut surfaces are then hatched to show them as cut. The larger three holes are no longer shown dashed as the hole edges are now visible.
Note that the picture does not correctly indicate the connection of gussets to the lower rounds - are they tangent to the 38 diameter or do they terminate above the centerline as shown?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
