Valentin-WSP
en respuesta a: aghavamzadeh
@aghavamzadeh ,
@aghavamzadeh wrote:
I am trying to understand this Paragraph Line Spacing in order to add blocks as bullets to each row.
It says Line Spacing 1.000x. So the Line Spacing should be 1, 2, 3 and so on
Where does spacing start from? When i measure it says 0,66 between the lines.
MText with height 1 is inserted at 0,0 and it is adjusted Top Left.
I attach the file here.
What I want to do is to add blocks at same increment as Line Spacing.
If it works for you, just place them at the same location as the default bullets.
See sample:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
