aghavamzadeh
478 Vistas, 4 Respuestas
Mtext
I am trying to understand this Paragraph Line Spacing in order to add blocks as bullets to each row.
It says Line Spacing 1.000x. So the Line Spacing should be 1, 2, 3 and so on
Where does spacing start from? When i measure it says 0,66 between the lines.
MText with height 1 is inserted at 0,0 and it is adjusted Top Left.
I attach the file here.
What i want to do is to add blocks att same increment as Line Spacing.
