cadffm
en respuesta a: pcaruthers
" how can that be that 3 different workstations are detecting different entities? "
That isn't the case. You are not familiar (not enough) with Object selection methods
and Hatch settings.
1. Turn on the message I wrote about (OPTIONS..)
2. Set VPMAXLINES to 10.000.000 (it is a user or workstation setting, not stored in your file!)
3. open your file
    A message appears about a problem about the hatchs (scales)
   Do not use the 'convert to solid' option
4. Run  ZOOM EXTENTS to see all visible content
    Press CTRL+A
   Check your properties palette, filter for Object type HATCH -> there are 10 of them.
    Check your properties Palette.
Some hatchs are on top of ohter hatchs, so you see less than 10, but you can move each by side,
this way you will see 10 single hatchs.
Sebastian
