micpfeifer
1732 Vistas, 5 Respuestas
bak files in temp folder
I have several PC's that periodically save ".bak" files to the "C:\Users\username\AppData\Local\Temp" folder in addition to the ".bak" file that the ".dwg" is in. I have a new Worksation that does not. I would like to make this workstation like the others, but I cannot find a way to enable this feature. After some reading it seems that this may not be an intended feature of AutoCAD at all.
I am using windows 7 with Auto CAD 2016.
I have attached a picture of an example of one of our .dwg folders on the server (this shows the .dwg file and typical.bak file location)
I have also attached a picture of the tempfile (with the additional .bak files and sv$ files)
Does anyone know how to enable this feature?
pendean
en respuesta a: micpfeifer
I believe the "temp" folder BAK files are a result of AutoSAVE kicking in because you're not manually saving often enough.
A double-edged sword: it's best to get in the habit of manually saving more often.
FTSRoann
Dear MicPfeifer,
Please review the following article, as it might assist you with your inquiry.
AutoCAD backup and autosave files
I also agreed completely with Mr. Saadallah's suggestion.
Regards
Mit freundlichen Grüßen,
Kind Regards,
Roann Knight
www.autodesk.com
FTSRoann
Dear MicPfeifer,
I just wanted to know if you were able to review the information provided and see how it went.
Regards
Kind Regards,
Roann Knight
www.autodesk.com
micpfeifer
Apologies for the delayed response, I have been out of town for a few of days.
I talked to personnel in one of our other offices this morning regarding this issue.
They informed me that our antivirus may be deleting all files in the "temp" directory daily.
I am going to create a different directory on the local drive labeled backup and remap the "automatic save file location" to see if this resolves this issue.
I will keep you posted on whether or not it works.
Thanks for your assistance on this.
rkmcswain
en respuesta a: pendean
Correct. Autosave works like a regular save in this regard. The first time, a .sv$ file is created. The next time it fires, the .sv$ file is renamed to .bak and then a new .sv$ file is created.
IOW - the .bak files in the %temp% location are your autosave files, one version older than the corresponding .sv$ file.
