Another way would be the usage of parametric constraints.
In the parametric tap use "equal" on the circles. (or the command GCEQAL)
But...i've never used parametric constraints in AutoCAD. (They are a powerful, must-use tool in Inventor)
It could end in a bad result, if you forget the constraints on one of the circles.
Therefore: i recommend to use blocks , like pendean suggested.
