It can be done with ease, if you redraw them this way:
Create a block with one of these arrow-things. The attachment point of the arrow are 0.0 coordinates in the block.
The arrow should face up or down.
Place the block along the circle with DIVIDE - select block (and write the name of the block) - allign yes - type in the amount of arrows you want.
Now you can change the direction of the arrows by opening the block and rotate all by 180°.
(Just be careful if you have this setting multiple times. Rotating the arrows this way will affect all circles.)
EDIT: oh...if the arrows (or whatever objects you drew in the block) are not symmetrical, you might need to mirror them in the block, not rotate.
