prestin_unique
468 Vistas, 5 Respuestas
mirror objects over arc
Is it possible to mirror objects over arc or circle (I want to mirror the objects from inside to outside the circle)
cadffm
en respuesta a: prestin_unique
no, butween is regular, or?
it's easy to create by using ARRAY or ARRAYCLASSIC
Sebastian
Valentin-WSP
@prestin_unique ,
Might want to take a look at @Kent1Cooper suggestion here:
Use APPLOAD to load the attached LSP, then type MAO - see sample:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
EnM4st3r
i also tried to change Lee Macs Quick Mirror to do that
;; Original code by Lee Mac: https://www.lee-mac.com/quickmirror.html
;; Changed to try mirroring objects along a curve
;; Mirror SelectionSet about selected object
(defun c:QM   nil (QuickMirror nil nil))
(defun QuickMirror ( single delete / *error* _StartUndo _EndUndo doc ent ss sscount sel p1 p2 o ) (vl-load-com)
  ;; © Lee Mac 2011
  (defun *error* ( msg )
    (if doc (_EndUndo doc))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
    (princ)
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (setq sscount 0)
  (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (or single (setq ss (ssget "_:L" '((0 . "INSERT")))))
    (progn
      (while (not ent)
        (setq ent (car (setq sel (entsel "\nSelect Mirror Object: "))))
      (while (< sscount (sslength ss))
        (cond
            (and sel
              (not
                (vl-catch-all-error-p
                  (setq p1
                    (vl-catch-all-apply 'vlax-curve-getClosestPointto
                      (list (car sel) (trans (cdr (assoc 10 (entget (ssname ss sscount)))) 1 0))
            (setq p2
              (polar p1
                (angle '(0. 0. 0.)
                  (vlax-curve-getFirstDeriv (car sel)
                    (vlax-curve-getParamatPoint (car sel) p1)
                1.
            (setq p1 (vlax-3D-point p1) p2 (vlax-3D-point p2))
            (_StartUndo doc)
            (if ss
              (progn
                (vla-mirror (setq o (vlax-ename->vla-object (ssname ss sscount))) p1 p2)
                (if delete  (vla-delete o))
              (progn
                (vla-mirror (setq o (vlax-ename->vla-object (car sel))) p1 p2)
            (setq sscount (1+ sscount))
            (_EndUndo doc)
  (princ)
Kent1Cooper
You can use the MAO command in MirrorAcrossObject.lsp, >here<.  [Oops -- someone beat me to it....]
Kent Cooper, AIA
It can be done with ease, if you redraw them this way:
Create a block with one of these arrow-things. The attachment point of the arrow are 0.0 coordinates in the block.
The arrow should face up or down.
Place the block along the circle with DIVIDE - select block (and write the name of the block) - allign yes - type in the amount of arrows you want.
Now you can change the direction of the arrows by opening the block and rotate all by 180°.
(Just be careful if you have this setting multiple times. Rotating the arrows this way will affect all circles.)
EDIT: oh...if the arrows (or whatever objects you drew in the block) are not symmetrical, you might need to mirror them in the block, not rotate.
