- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a laser cutter which is currently about .4° out of square, for the purpose of this thread assume that this can not be changed or corrected on the machine at the software or hardware level. I normally use INV to make my sheet metal parts and export the flat patterns for cutting.
To cut a square on this machine I have to draw it out of square which is easy to do, not so much with a complicated flat pattern. My work flow would need to be INV>Autocad skew .4°>import into laser or better if I am missing something.
The links in the link that you provided are all dead in the OP. These posts are much closer to what I am trying to do with the one talking about LISP being the closest, I have never used LISP and for now I hope not to. I have included a drawing.
https://forums.autodesk.com/t5/autocad-forum/stretch-on-an-angle-or-skew/m-p/11674799
