- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Need an option like Skew, CNC cutter is not square.
I found myself here after realizing that ACad 2024 does not have a skew command. I have a situation where a CNC cutter is not square and I can't use it because ACad does not have this seemingly simple command. Help if you can and want to.
[ The subject line of this post has been edited for clarity by @pendean Original: Suggestion board? Skew. ]
[INVENTOR provides the base .dxf only and does not skew, "Need an option like Skew from INVENTOR: CNC cutter is not square"]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
SKEW can be interpreted in many ways in AutoCAD, which of these many suggestions in this similar post are you trying to do
https://www.cadtutor.net/forum/topic/49817-skewing-a-block-verticallyhorizontally/
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have a laser cutter which is currently about .4° out of square, for the purpose of this thread assume that this can not be changed or corrected on the machine at the software or hardware level. I normally use INV to make my sheet metal parts and export the flat patterns for cutting.
To cut a square on this machine I have to draw it out of square which is easy to do, not so much with a complicated flat pattern. My work flow would need to be INV>Autocad skew .4°>import into laser or better if I am missing something.
The links in the link that you provided are all dead in the OP. These posts are much closer to what I am trying to do with the one talking about LISP being the closest, I have never used LISP and for now I hope not to. I have included a drawing.
https://forums.autodesk.com/t5/autocad-forum/stretch-on-an-angle-or-skew/m-p/11674799
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You could simply use the UCS (Command) to skew your User Coordinate System 0.4 degrees.
No need to code anything.
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Changing the UCS does not do what I need, it changes both the x and y axis and I need the y to stay put while the x sees a .3935° rotation.
All vertical lines at 90° need to stay at 90°, all horizontal lines at 0° need to change to .3935° and everything in between needs to change. I need to trick the machine by altering my drawing so that any feature which would involve using the gantry, or X axis, has a slight change in angle.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@josh wrote:
...what I am trying to do with the one talking about LISP being the closest, I have never used LISP...
Not a problem: here is an online tutorial showing the different ways to load LISP, its easy to start as long as those LISP are actually what you need
https://www.lee-mac.com/runlisp.html#:~:text=How%20to%20Run%20an%20AutoLISP%20Program
@josh wrote:
...for now I hope not to...
sadly sometime you don't get a choice. See if any others respond then decide on your next steps.
