cadffm
en respuesta a: crawfordscott
>>"the Block Name column is showing a mixture of correct Block Names and the annoying U (followed by number) block name"
>>"Anyone got a clue as to what's happening."
Annoying or not, all the names are right and the REAL blocknames!
>>" Yet when I extract data the "traditional" way ie Autocad's Extract Data command this doesn't happen."
>>"The list of blocks show their correct name."
No, Dataextraction showing a fake name, same for properties palette.
Background: ATTIN/ATTOUT are older than the "dynamic Block" feature.
Dynamic Blocks: Everytime you change an dynamic property value, Acad creates a new block (names are Unnn),
the blockreference linking to this block, but properties palette (or dataextraction command) continues to cheat the original name to you.
Attin/Attout doesn't know about this feature and will display the real anonymous blockname
Sebastian
