paullimapa
en respuesta a: JOHNLLOYD7213
There should not have been 2 updates for AutoCAD 2024 last week.
Were they updates that have been around for a while and you just decided to install them now?
Does your About screen now show U. 152.0.0 AutoCAD 2024.1.2?
If true, 2 versions back would be 2024.1 which came out way back in July of 2023:
https://help.autodesk.com/view/ACD/2024/ENU/?guid=AUTOCAD_2024_1_FIXED_ISSUES
You also mentioned:
"the resultant PDF file always opens full window without all the shx "comments" junk to the right of the drawing that I get when I use the built in pdf.pc3 files"
Perhaps you can do a screen capture or share a sample pdf from your adobe pdf.pc3 vs built-in pdf.pc3 to explain what you're seeing ?
Paul Li
IT Specialist
@The Office
