JOHNLLOYD7213
449 Vistas, 5 Respuestas
Thirty second lock-up after plotting
After installing two autodesk updates last week via the autodesk access application, autocad locks up for 20 - 30 seconds after plotting to PDF. I use the adobe pdf.pc3 file because the resultant PDF file always opens full window without all the shx "comments" junk to the right of the drawing that I get when I use the built in pdf.pc3 files. The PDF generates properly and quickly, but the plot job progress dialog stays on the screen for about half a minute effectively locking up the autocad application. I just tried the built in PC3 files & the problem is the same. This never happened before last week's updates. So, is there a way for me to uninstall these updates, or should I just wait for the imminent release of 2025 & hope this problem goes away with the new version?
