justin_cruea
223 Vistas, 2 Respuestas
problems loading drawings from parent company in China
Hi, I have an issue with loading files from our tool builders in China. I work for an automotive die stamping company and our files come from China where our tools are made. The problem I'm having is when I open the file, this pops up.
  Then after clicking Specify replacement
 I have contacted our parent company in China to see what software they are using, They are using AutoCAD 2005 simplified Chinese. So somehow the AutoCAD 2023 that I am currently using is not communicating with the AutoCAD 2005 simplified Chinese ??? Am I missing something here???
VincentSheehan
en respuesta a: justin_cruea
You need to get a copy of their SHX font files.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
pendean
you need to ask the file creator to share all missing content (that includes SHX bigfonts and shape files) with you: if they use AutoCAD2005 that would be ETRANSMIT command, but it will need to be set to capture all of that content.
here is a tutorial for you and them:
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-9A2F96E5-34D1-4504-A5F3-54BCD410041D#:~:text=...
Nope, you cannot usually find any online or built-in "something" you have that will be a 100% true substitute. Nope, AutoCAD 2023 can open AutocAd2005 file just fine, you're just missing content unique to them that they need to share with you.
HTH
