Gazouli
371 Vistas, 2 Respuestas
Is it possible to adjust the dimensions seamlessly of an imported PDF?
Hi all! Just a beginner here figuring things out. So I just imported a PDF file of an architectural plan (having isometric views such as elevations & sections) to a new AutoCAD document and now I need to make a few adjustments to the dimensions but when they were imported the dimensions became just plain text and hence disconnected with the drawing itself. Is there an easier way to adjust the dimensions along with the drawing? If so, please let me know. Thank you in advance!
Additional info that might help: I know how to match the scale of the original drawing to the viewport. I just want to find a way that will not require me to remove all the previous dimensions, adjust the size of the drawing one by one, and bring out all the revised dimensions again.
