Kent1Cooper
en respuesta a: GSpro
If you really mean thickness as AutoCAD means it, the code is 39.  See the DXF Reference for a Line.  But in AutoCAD, thickness is "up off the page" in the Z direction.  If you really mean lineweight, see 370 in the Related Reference to Common Group Codes.  If in the case of a Polyline, you really mean width, that's also different, and controlled separately for each end of each segment.
Kent Cooper, AIA
