pendean
en respuesta a: xnguyenY935A
Thanks for the detailed replies: so you are indeed using AutoCADMECHANICAL, about the only correct variant that I am aware of to do what you are asking about. Does it have and do you use Parametric Tools? It seems like what you are asking about, explore it in HELP starting here https://help.autodesk.com/view/AMECH_PP/2024/ENU/?guid=GUID-899E008D-B422-4DF2-AC8D-1A4F5701ED4E
I see you have posted in the dedicated MECHANICAL forum before, which is not this general AutoCAD forum: have you had a chance to pose your more specific questions (see your replies to my questions) over there for help? I suspect they will want you to share your work in a DWG file etc.
FUSION is the software to go to if you truly wish to up your game in my opinion: its not like AutoCAD but much more advanced and less clunky to use.
