doni49
en respuesta a: mikegera
I don't have time right now to actually write it, but it should be possible to write a lisp routine that would need to be run before you do the undo command.  It would save the current view scale and coordinates of the view's corners.  Then you'd do your undo operation and run the mating routine that would restore the view to the previously saved state.
It would probably be wise to also save and restore all the viewports on all the layout tabs.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
