02-26-2024
11:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-26-2024
11:20 AM
>>"Some of the .xtp files picked up the new location, most didn't."
If you talk about the content in .xtp
that was your turn (you tried a find&replace).
If not all pathes correct, you had a problem with your find&replace.
I miss one more information:
After import o e of the .xtp files (where you had successful f&r):
The file path is correct (insertion tool property Path) and is working or not?
'Documents' is a special animal, but if you used the full path c:\users\.. I expect it should work as it did 1000 times before.
Sorry, without the data, I can't help more.
(For a test, you can copy your .dwg to c:/temp/test or another local folder without special characters
and run a new test with the original .atc files.
This MUST work well.
Sebastian
